Hello all! Just wanted to know if there is anyway to export .mtl materials from keyshot 4. Right now I can only find the way to export .kmp. Thanks!!
I don't know if there is a work around with KS but normally when i export .obj from 3ds max i get an associated materials .mtl, if you don't have 3ds max you could try the free version of meshlab to export obj with mtl.
Dunk
The .kmp file is a zip file that contains all textures and labels and the .mtl file. Keep in mind that this .mtl file can only be used in KeyShot.
