Hi
Im looking for a way to get only one side of a shape painted.
Example:
There is a detail in a model that is a tube, lets say lens hood for a camera.
Is there a way to get only the inside of the hood in a material/color and another on the outside?
Or the inside of a flowerpot a lamp screen, a cupboard etc.
I suspect this can't be done in Keyshot but if i export the part as OBJ and open it in C4D perhaps.
Im fully aware of that this probably is no piece of cake but i would very much appreciate if someone could suggest a workflow that i could look into.
Regards
Mikael
In your native CAD, just apply UV Mapping, (any color) to each surface you wish to differentiate.
Hi
Thanks for your reply.
I know this is possible, but i get step files and there is no way for me to affect the pre work in CAD.
I was thinking more in a post CAD way here.
Mikael
If it's not a solid, then I don't believe there is a way to do a 2-sided material in keyshot anyway.
What 3D software are you using? Splitting a part into pieces is a modeling change. I think the only way to do what you're asking is to use a decal as the second material.
Or you could just render it twice as 2 different materials and photoshop the results together.
I think you are right. I simply have to get it done from the source rather then trying to do it afterwards.
I will lay my efforts there instead.
Mikael
