Technical discussions => General discussion => Topic started by: chippwalters on September 24, 2010, 12:43:51 PM
Title: Blurred Reflections on Ground Plane
Post by: chippwalters on September 24, 2010, 12:43:51 PM
Is it possible to create a blurred ground plane reflection? I see in the Environment tab where I can turn on the Ground reflections, but I don't see where I can make them blurred.
I don't want to have to add a ground plane and then build a lighting stage to hide the horizon line, etc.. I just want a small bit of blurred reflection in my image. See Image below:
TIA!
(http://www.widgetgadget.com/stuff/KeyshotQuestion.png)
Title: Re: Blurred Reflections on Ground Plane
Post by: guest84672 on September 24, 2010, 02:53:46 PM
You can't right now. Simply import a ground plane and apply metal. Then control the roughness of the metal material. Make sure sharp glossy reflections is checked in the Environment tab.
