Technical discussions => Animation => Topic started by: PeterSwift on August 10, 2016, 04:46:57 AM
Title: Axis on object
Post by: PeterSwift on August 10, 2016, 04:46:57 AM
Im rotating the green object then I'm gonna make a animation on the blue object as well using the green as pivot point. WHY does not the axis follow the green object?  Is just going though the center and is static.
Title: Re: Axis on object
Post by: DriesV on August 10, 2016, 06:14:46 AM
In this scenario results will be more predictable of you create a proper hierarchy. This means grouping/dragging the blue cylinder underneath the green one.
You can then animate the group, in order to rotate the pivot.
See attached example.
Post by: PeterSwift on August 10, 2016, 06:27:19 AM
Quote from: DriesV on August 10, 2016, 06:14:46 AM
Thank you! So now I know it works. But Keyshot just dont updated the Axis when reselect it after or in a animation. Good to know!  Keyshot should fix that.
