Hi guys!
This is my last model with Maya from the serie of tutorials for beginners.
I hope you like it and you can make good critics to improve it.
The first two renders are with niquel material and changing a bit the color.
(https://dl.dropboxusercontent.com/u/66505097/Pistola%20videojuego/Pistola%20Render.27-3.jpg)
(https://dl.dropboxusercontent.com/u/66505097/Pistola%20videojuego/Pistola%20Render.28-2.jpg)
The third one is with a medium translucent material.
(https://dl.dropboxusercontent.com/u/66505097/Pistola%20videojuego/Pistola%20Render.30.jpg)
and these ones are adding some granite texture as a colour and modifying a bit the values.
(https://dl.dropboxusercontent.com/u/66505097/Pistola%20videojuego/Pistola%20Render.32.jpg)(https://dl.dropboxusercontent.com/u/66505097/Pistola%20videojuego/Pistola%20Render.35.jpg)
Nice. The second one is interesting with that ground textures. Shame it's so dark though, because there's some great detail on the grip. The grip would also look good in wood or leather, or with a wrapped leather look!
Josh
Nice looking model. Try using some textures for a "distressed" look. maybe the new "Scratches" procedural?
I will add some more detail to it and try that stuff and the leather hander... I will try to model some seams, will see.
Low size image but it's the first one, (a good option for next keyshot, could be the possibility to modify the settings of the files after you put them in the render list).
(https://dl.dropboxusercontent.com/u/66505097/Pistola%20videojuego/Pistola%20con%20costuras.45.jpg)
Looking good with the texturing! Are you using ground reflections or a ground plane? The reflection could use some roughness as it is a little distracting from the actual model.
I used ground reflexion... but the point is that I'm horrible with PS for post production... and I can not improve anything the image that I get from KS...
I have this others renders...
(https://dl.dropboxusercontent.com/u/66505097/Pistola%20videojuego/Pistola%20con%20costuras.48.jpg)(https://dl.dropboxusercontent.com/u/66505097/Pistola%20videojuego/Pistola%20con%20costuras.53-1.jpg)
(https://dl.dropboxusercontent.com/u/66505097/Pistola%20videojuego/Pistola%20con%20costuras.53.jpg)
