AMD Ryzen Threadripper 2990WX - 455 FPS
Started by richardfunnell, April 26, 2019, 10:03:05 AM
richardfunnell
Got a new workstation yesterday, excited to have a much more powerful rig! Puget Systems helped spec this system out for KeyShot work, as well as being able to handle relatively heavy GPU based CAD/3D.
Camera Benchmark: 455 FPS
CPU          AMD Ryzen Threadripper 2990WX 3.0GHz 32 Core 250W
RAM          Crucial 32GB DDR4-2666 (4x8GB)
GPU          PNY Quadro P2000 PCI-E 5GB
Motherboard       Gigabyte X399 AORUS Xtreme
Great system, and great support from Puget. I ran into a few issues with the motherboard (as I think others have) but their team was able to troubleshoot & identify the problem.
Eugen Fetsch
This is what I see on my 2990WX.
mafrieger
@camomiles Do you see these results also after 10minutes+ of full load like richardfunnell? Or is it the turbo when everything is still cold?
Eugen Fetsch
Yes, I can see the same results after 10+ minutes. The FPS is between 495 - 517, but 70% of the time over 500 FPS.
mafrieger
thanks for detailing this!
so there may be some other differences with in your setups.
Some time a ago a wrote about possible impact factors like Keyshot version, OS and lots more.
If you are interested in, just have a look:
https://www.keyshot.com/forum/index.php?topic=22319.0
richardfunnell
Mine was giving me readings all over the place too, definitely hitting 500+ but not consistently. I haven't attempted to adjust clock speeds or any other settings, but I'm hopeful that some tweaking will help out :)
@mafrieger thanks for the link! yeah I'll have to push the setup a bit more and see where I land.
LM6
Hi Chaps...Ive just started working on a similar rig...2990
Iam getting 550-560fps when the cam scene first loads then if I dont touch anything it slowly drops to around 500fps
If I start moving the camera it boosts up to 1300fps or down to 430 depending on the angle and if the camera lens is in shot.
I would be interested to hear what cooling solution you are using, whats cpu temps your getting, what speed the cpu is running during the test and what your DB levels are like?
Peter
DMerz III
 :) Would also love to know your room's ambient temp when taking those readings.
Eugen Fetsch
Running a 2990WX and a Dual E5-2690v4 Xeon together, the only cooling solution I can recomend, is this mitsubishi divice over my head  ;D
Eugen Fetsch
#9
Seriously:
We have "Noctua NH-U12S TR4-SP3" for the 2990WX. Didn't measure the noise level, but it is very silent. The biggest issue is the power supply. The "Dark Power Pro P11" makes far more noise than the CPU fan.
LM6
Quote from: camomiles on May 09, 2019, 11:13:56 PM
Seriously:
Thanks for the info, so what CPU temps is that Noctua fan keeping the cpu at when rendering in Keyshot, iam surprised your saying its silent
I currently have a Wraith Ripper but I don't like it.
Eugen Fetsch
Quote from: LM6 on May 10, 2019, 02:50:27 AM
Between 65-67 °C
LM6
#12
Quote from: camomiles on May 10, 2019, 02:53:19 AM
Between 65-67 °C
Yes,  I have the same temps, going to try a Noctua CPU cooler next week.
Thanks again  :)
LM6
Between 65-67 °C
Sorry I forgot to ask, what is your CPU temp when idle?
Eugen Fetsch
I'll check next week, when back in the office.
