animation low quality pleaaaaaaaaaaaaaaaaase
Started by bebetto, September 01, 2020, 04:34:58 PM
bebetto
hi everyone !
I would know the best setting to do for a high quality animation ,
for info i used 60 pfs ,
thnx a lot , glad to waiting your explications :)
Justin A
Based on the video it looks like the samples are to low.  You could reduce the FPS to around 24-30 and increase the samples.
The best way to do this would be open the HUD on the real time render by pressing H.  and let the image rez up, once the image looks good to you that is what you should set your samples to in the render options.
bebetto
Thanks very much for your answer... So high fps give us a low quality??
INNEO_MWo
(F)rames (p)er (S)econd doesn't have not a real effect to quality, but samples does! The only effect with a low FPS value is, that you'll get some flipbook animation effect.
bebetto
Thanks for your answer... I wait that the pictures comes good and i take a same samples to put it in option but always my animation is too bad
