Issue regarding turntable of ground plane
Started by nirmall, February 04, 2021, 11:25:42 AM
nirmall
Hi Keyshot lovers,
i am trying to create a turntable animation where my ground plane also moves 360 degree with the product, however my product moves 360 degrees but my material on the ground plane does not animate.
Any help would be appreciated
TGS808
Apply the same turnable animation that you used on your product to the ground plane. You can copy and paste it. Do that, and the ground plane will move with the product.
Anindo Ghosh
Would the camera Orbit animation give you the result you need?
If you need the environment to stay static relative to the camera, then applying an Environment rotation animation identical to the Orbit should do the trick.
TGS808
Quote from: Anindo Ghosh on February 04, 2021, 07:52:13 PM
You're making it more complex than it needs to be. Environment rotation isn't necessary. If he follows what I posted, he'll get exactly what he wants.
nirmall
Quote from: TGS808 on February 04, 2021, 06:14:52 PM
did that, but still ground plane is static
nirmall
I am applying a jpeg material to the ground plane, you guys think that could be the reason why the ground plane is not shoing any movement??
TGS808
Quote from: nirmall on February 05, 2021, 08:53:28 AM
No. It will work with a JPEG or procedural. See attached KSP.
