Setting a Default Template
Started by m2tts, February 10, 2012, 05:34:43 AM
m2tts
I have a problem importing SW2012 files. Some surfaces will not import. i know this is a known issue, and the old importers won't work on 2012 files. The Plugin for 2012 is importing these surfaces; BUT, there is no way to pick what starting template you are going to use when invoking the plugin within SW. I'm rendering a series of products that want to use the same cameras and environment. How do I set what template Keyshot will use to place the SW file?
Simply setup the bipfile, and rename it to startup.bip. Then put in in the bin folder. Done.
m2tts
Yes Thanks, I figured that out. There should be a dialog within the plug-in that allows you to pick which file to push into. It would be good to be able to push your geometry into a previous bip file that already has geometry too.
Yes - this is something that we are looking at for the next version of KeyShot.
