Main Menu
TetraBot
Started by Despot, November 14, 2012, 08:08:37 AM
Despot
I love using KeyShot to try and achieve realism in my materials, this time I was going for distressed and used coated plastics - 3 different bump maps were used to achieve the aged look...
I've got to say it's great not having to wait half an hour or more (like in other renderers) to see if things look ok
Thanks for looking...
original model by Stanislav Marchevsky...
J
Awesome - when you say 3 different bumpmaps, do you mean a different bump map for individual parts?
Seghier
NICE ; can you try to reduce the scale of bump  and use negatif height
DriesV
Absolutely great!
What software are you using to model these contraptions?
Despot
Thanks Thomas, each part uses a different bump map that was created by merging 2/3 separate textures...
Seghier : I'm assuming you mean 'bump height' when you mean 'scale'... it s extremely low as it is, 0.03 i think, it does look extremely scratched, but he's been around a bit ;-)
The bump maps used are using a heightfield where the scratches themselves are dark/grey to black, so I dont need to use a negative bump scale value - some of the scratches do look raised, but I think you'll find that that cannot be avoided, its an issue with the bump mapping paradigm itself and the way the scene lighting interacts with it... it's almost an optical illusion
J
Despot
Just realised I was talking utter rubbish when I said the bump value used was 0.03... it was actually 0.12
So I could reduce it, but I've found that there is a threshold that once hit, any reduction in bump value has little or no difference visually...
J
Seghier
yes bump map somtimes look bad ; i mean the scale of bump texture
Despot
Quote from: Seghier on November 14, 2012, 11:24:46 AM
Ah ok, Hmm, why would i want to change the scale when its not using the default value anyway and I'm happy with how it looks visually ?  ;)
tsunami
Great work as usual from u..i like it's awesome..seems really real..
Could u show us what bump image u used for?
br3ttman
Quote from: Thomas Teger on November 14, 2012, 08:44:12 AM
Multiple bumpmaps per material (as well specular, opacity, and color) would be a nice feature, just like you have currently with labels.
Despot
Yeah, layered materials would be great - you never know it might be in V4
mmmster3d
that would be the bees knees if they did that for 4!
nice rendering :) keep it up
Despot
Quote from: tsunami on November 14, 2012, 12:48:17 PM
I'm not at work for another couple of weeks, thats where the scene file is...  I'll post it when im back
But to be honest, most of the bumps I use are done from scratch anyway...
I start with a photographic texture that contains dents and scratches and then use Photoshop to isolate them, then duplicate them and rotate and scale until I'm happy... then convert to Black and White.
J
