Pb texturing
Started by J0hnJ0hn, February 07, 2013, 02:12:57 AM
J0hnJ0hn
Hi guys,
I am trying to add texture on a model i made on rhino, but it doesnt looks good
Once i put texture on the "model", the one goes into different scales and is splitted into different parts
It doesn't looks good...
Should i restart from rhino ?
Is there smt on keyshot to modify this pb ?
I Really  don't want spend hours to add pattern on photoshop
Thanks.
Robb63
Try setting the texture mapping to "Box Map" in Keyshot. If that doesn't work, Rhino 5 has UV mapping. Try watching this video that explains how to set it up in Rhino 5
https://vimeo.com/58457893
J0hnJ0hn
i'm using Two laptops: One for Rhino, One for Keyshot.
Because keyshot doesn't work with the rhino one...
Is this going to make a difference ?
I can't find box mapping on keyshot...
PhilippeV8
#3
It shows on this screenshot as the bumpmap, but for the color map, it's the same !
What you can do also, is to give each face a different color in your CAD program, then in KeyShot aply the same material to all faces as a boxmap, unlink them, then move around each texture on each face to manualy align them ... which is a bit of work, but it does work.
J0hnJ0hn
I might unroll the surface, apply the texture on photoshop and add this on keyshot !
J0hnJ0hn
This will take ages... but i'm gonna try
Is there not any softwares specialised into box mapping ? like a pluggin for rhino ?
Robb63
Did you watch the Rhino video I added the link to? It shows you how to apply the box map UV very quickly right in Rhino.
