Abbe?
Started by NDenekamp, June 27, 2013, 12:24:27 PM
NDenekamp
Hey,
I just discovered I can't set Abbe value for the Gem material, or any other material where it should show up..
Also, working with this material type makes KeyShot very unstable.. if I try to drag the preset diamond onto an object, that will pretty much stall the application completely..
Any ideas what the issue could be?
N
You have set the roughness value to gloss. This seems to rename the ABBE parameter. This shouldn't be the case. We will fix it.
NDenekamp
Thomas, you're right. After i changed that preference, it shows up as Abbe, and defaults to 0 (instead of gloss 100)
It's however still acting very nervous when I use it, and crashed/stalled the application (the live preview stops updating) and I end up having to force quite it.
I have seen this as well, but not to an extend where it actually stalls. It is just a delay. But it has already been fixed.
NDenekamp
I've installed 4.0,x then a couple of beta releases, and now 4.1.35 all as updates. Would it maybe help to do a clean install of just the latest version?
N
Sorry - I should have been more specific. It has already been fixed in a new update, not 4.1.35.
