Animation Output not the full length
Started by techdoku, March 01, 2015, 11:45:38 PM
techdoku
I would like to animate a 360 rotation over 15 sec.
i did so few times and everything is fine.
but since several days after output the video is max. 5 seconds long instead of 15.
sometimes 1 second, sometimes 3 seconds.
in preview mode i see that tha animation would render correct. i think it is a problem with the final coding output (because i see from 1% to about 14% and than the window is gone).
i tried it with network rendering - same problem
i tried it with lokal rendering (standard and in background) - same problem
i tried reinstallation of ks and ks nr - same problem
what tha hell is going on?
the fact is that i am in hurry to finish my project and i cant render any animation with my desiared video length.
any ideas?
richardfunnell
Is it possible that you have "Work area" or "Frame range" selected under your animation render settings? This would only render out a portion of your animation.
techdoku
no!
i can see the rendering is done with all frames - but the outut is damaging the video. so it shrinks from 15 sec. to 1 second.
richardfunnell
Hmm, what are you settings for the frames per second?
techdoku
hi Richard,
what do you mean with frame settings?
i cannot change the framerate.
when i create a 10 seconds animation it shows 300 frames (so the value of 30 frames are fixed).
can you change the framerate?
richardfunnell
Ok, so it looks like you're rendering at 30FPS, I was wondering if that might have been a factor.
Yes, you definitely can. It's under the timeline settings in your animation window, screenshot attached.
Can you send an email to support@luxion.com for this issue?
