KeyShot6 Plugin for Wildfire5.0 !?
Started by ohashi3d, November 12, 2015, 01:53:33 PM
ohashi3d
Congratulations for KeyShot6 release!
Can we expect KeyShot6 plugin for Wildfire5.0 in the near future!?
For Wildfire5.0/4.0, the plugins page shows only KeyShot5 plugins,
and oddly enough, the older versions (3.3) are linked there now...
Formerly the version 3.6 was linked there and it's still available, for the example:
https://www.keyshot.com/install/plugins/proe/wildfire5/keyshot5_wildfire564_plugin_3.6.exe
Is there any reason for linking to older version!?
And, is the plugins development for Wildfire5.0 discontinued!?
Though Wildfire5.0 maintenance by PTC has been ended in this September,
I still want to use KeyShot6 with Wildfire5.0 for the time being!
Thanks in advance and best regards,
kyosen
KeyShot
You may still be able to use the KeyShot 5 plugin with KeyShot 6.
INNEO_MWo
Hi.
The 3.9 Plugin still runs with KS6. And you can always save the bip and import/update your scene.
DonChunior
And what's about the Wildfire 4.0 plug-in?
Unfortunately we need to stay on Wildfire 4.0 till December 2016:-\
INNEO_MWo
Just use your current plugin with export option and import the bio in your scene
hope that helps
DonChunior
Quote from: MWo on November 13, 2015, 12:23:34 AM
hope that helps
But live-linking is not available then, is it?!
INNEO_MWo
You can use live linking like:
Export the bio to create your scene
Make Geom changes in CAD and export new bio
Import your new bip in current scene with third import option (in dialog). That's a refresh like live linking.
Otherwise create a mat template from current objects, delete cad data and re-import the new bip with the mat template.
That was the trick before live linking came in.
(written on mobile device with no time - sorry)
ohashi3d
Thanks!!
To my surprise, after just installing KeyShot6,  KeyShot5 plugin on Wildfire5.0 came to call KeyShot6 instead of KeyShot5,
and it looks live-linking is working well :)
Then, can we select the invoked KeyShot version with any simple setting?
...For a while, still I must supply KeyShot5 data to my colleagues...
I tried just uninstalling KeyShot6, but then KeyShot plugin came to not working at all, standalone KeyShot5 still works fine though!
After re-installing KeyShot5, the plugin came to working again.
Next, after re-installing KeyShot6, the plugin came to invoking KeyShot6.
And next, after running keyshot_w64_5.3.6_update.exe, the plugin came to invoking KeyShot5 again...
...so, It looks like the invoked KeyShot version depends on last run installer version.
How the KeyShot plugin decides invoking version!? ...by any environment variable or Windows registry!?
