Texture electronic cable
Started by Skampus, December 01, 2015, 07:24:58 AM
Skampus
Hi everybody,
I need a short advise. I try to texture a cable. It has to be two colours going along the cable not twisted as you can regard at the screenshot.
I try a few ways without success ..now I´m blocked :P
Has someone the ultimate idea.
TpwUK
Map a gradient type procedural material using cylinder as the mapping type ?
Skampus
Quote from: TpwUK on December 01, 2015, 05:10:49 PM
Thanks Martin for that
Done ..the result is not that I hoped for. I add another Screen from a real cable. So it should lool like. Any idea is still welcome  :D
TpwUK
I just tried it too and got unexpected results. What file format is your model in ? I tried 3DM
Skampus
TpwUK
Add this material to the diffuse slot or texture slot if using translucent material, use uv mapping type and scale to suit
Skampus
Hi Martin,
I should start thinking the simple way again :) Thank you, it works !!
Best
Markus
mertmg
Quote from: TpwUK on December 02, 2015, 06:08:06 AM
thanks for the trick Martin
