Glenlivet XXV - Single Malt Scotch Whisky
Started by Martin Kamminga, February 13, 2016, 05:28:04 AM
Martin Kamminga
Hello :)
My newest project. I found this one quite a challenge, especially the label, which is a very rough paper material (with different metallic finishes for the text), instead of the more commonly used plastic labels.  My intention was to achieve a very pure and raw photo look.  :-)
Esben Oxholm
Perfect!
I think this is the best KeyShot bottle I have ever seen. The label is looking amazing!
TpwUK
Very impressive - the labeling work is excellent and highly effective
Martin Kamminga
Quote from: Esben Oxholm on February 13, 2016, 05:43:56 AM
Perfect!
Quote from: TpwUK on February 13, 2016, 07:01:31 AM
Woah, thank you for the positive feedback guys! :-)
Speedster
QuoteI think this is the best KeyShot bottle I have ever seen.
Wrong!  I think these are the best KeyShot renderings of anything I've seen yet!  Superb work!  The splash in the glass is over-the-top! The DOF may be a tad excessive, but it works!
Finema
Ouahhh !
Really, really good job !
Bravo Martin.
Can you tell us more about this project?
Paper texture, emboss text, etc...
Bravo !
Shubham_Kapoor
Quote from: Speedster on February 13, 2016, 12:29:58 PM
Totally agree with you, these are spectacular and breath taking renders.
Best Renderings in this forum yet.
Give this man a T-shirt already.
Martin Kamminga
Thanks for the amazing response everyone :)
Quote from: Finema on February 13, 2016, 11:24:34 PM
Ouahhh !
Bravo Martin.
Bravo !
Well, what I did, is that I recreated the label using reference images. I then divided all the elements of the label in different layers, so that they could be assigned different label materials. Like so:
For the glas I used a solid glass material.
The liquid material was a dielectric shader with a gradient transmission.
The lighting ended up being quiet simple. I used two planes, a soft round pin and an emissive material as backlight.
Hope it helps :)
Finema
Thanks Martin , it's very interesting.
I'm packaging designer and personnaly i use Color Key Mask in keyshot 6. It's very usefull.
Magnus Skogsfjord
This is one fantastic piece of visual work. Perfect indeed! Well done.
Justin M
Martin Kamminga
Thank you all!
Quote from: Finema on February 14, 2016, 12:46:00 AM
Never got the chance to try out that one, will definitely check that feature out some day :)
Neo
WOW! Great render martin! definitely the best bottle render i've ever seen! really great...for the bump maps of the paper did you used the keyshot's standard normal map?( paper_normal.png, black metal, gold metal)
Esben Oxholm
Quote from: Martin Kamminga on February 16, 2016, 10:12:55 AM
Thank you all!
For a quick introduction take look at this part of the advanced material control webinar that Dries did a while ago. I think it is pretty cool.
Starts 42 minutes in:
https://youtu.be/5umbUNOT6HI?t=41m56s
