Depth of field works incorrectly in KeyShot 6.2
Started by Ricchezza, September 02, 2016, 09:47:57 AM
Ricchezza
Hey guys! There seems to be an issue with depth of field in keyshot 6.2. Check the images i attach to the post. As you can see when f-stop number is low - you cant see a thing in a viewport. Only when it reaches 200-256 (btw 256 is a limit, you cant go higher) the image starts to appear normally. But still it is not the same with KS5. And it is bad because i no longer can add just a slight blur on the background of an image. Even at the 256 f-stop value the background is heavily blurred. It is not a hardware problem cause its the same on two of my computers. Any suggestions? Thanks to u all)
NM-92
Have you tried changing the scene units ? Usually that helps when the parameters get messed up.
Ricchezza
Quote from: NM-92 on September 02, 2016, 01:40:25 PM
How do i do it actually?
LayC42
Quote from: Ricchezza on September 05, 2016, 06:11:57 AM
In main menue tab: Edit->Scene units
