White noise
Started by Zvi, January 05, 2017, 02:09:53 AM
Zvi
How can I solve this problem of white noise?
Zvi
Another attachment
Finema
Hi
have you try without Global illumination ?
NM-92
In some cases, rendering in interior mode can help.
Will Gibbons
Before your question can be answered, we need to identify the cause of the noise. If you can attach your scene as a .ksp file, it'll be easier to help. Do you have physical lights in this scene? What are your render settings?
Zvi
Quote from: Finema on January 05, 2017, 06:15:23 AM
Hi
Thank you, bu it didn't changed.
Zvi
Quote from: Will Gibbons on January 05, 2017, 06:59:24 AM
This are the settings.
Zvi
Quote from: NM-92 on January 05, 2017, 06:55:43 AM
Thanks a lot, it really helped, but  still remains some noise.
Finema
have you try to reduce Ray Bounces ? 50 is not necessary in your render
Zvi
Quote from: Finema on January 05, 2017, 10:09:13 PM
The last attached image is in interior mode with only 6 Ray Bounces, and still there is white noise.
Finema
try to increase samples (32 or 64) in yours metal materials
Zvi
Quote from: Finema on January 05, 2017, 11:59:22 PM
I did so with 64 samples, and the white noise is still there, as you can see.
Esben Oxholm
Do you use any emissive materials or physical lights in your scene?
Will Gibbons
Also, add some subtle roughness to your materials that are showing white spots, and make sure they have a material samples set to about 16. Your render samples should be good enough around 64. Make sure you have global illumination turned on. 10 Ray Bounces should be plenty.
Zvi
Quote from: Esben Oxholm on January 06, 2017, 06:37:55 AM
Not close to this noise.
