Depth of labels
Started by Philrider7, June 16, 2011, 10:05:32 AM
Philrider7
I am showing you part of a project that has glass with a silkscreen on it. I got the glass with a thickness (solid and in the option, I checked 2 sides and I put the silkscreen as a label in png. I tried to project it with normal projection, but it wasnt doing it and after that I went it planar z and its showing the labels on the other sides of the glass too!
I understannd than depth controls the surfaces that sees this labels, but depth is gray out on planar z!
Is there something i didnt follow correctly or any better solution?
Phil
What do you mean by "normal didn't do it"? Click on position and move the label into place once you applied it.
Thomas
