Keyshot 7 plugin not working in 3dsmax 2018
Started by OccultMonk, October 01, 2017, 05:58:52 AM
OccultMonk
Keyshot 7 plugin installer does not install to 2018 (Latest installer) .gup file was also not in the 3dsmax 2018 directory. The help .txt states that 3dsmax 2018 is supported.
OccultMonk
Has anyone installed this into 3dsmax 2018.2? It does not create the key shot menu and the plugin is also not installed in the 3dsmax folder. The .ini file states that it is compatible with 3dsmax 2018.
We have a fix for it. Should be available later today.
Fabbrica
Having a similar problem with Keyshot 7 and 3DS Max 2018.3. The  .gup file is located in the plugins folder of the Max program files, but no menu options appear in Menus drop down of Customize UI.
feher
Have the same problem here. 3dsmax 2018 plug-in will not work.
Tim
Autodesk insist on changing things mid-release which has a tendency to break 3rd party plugins. I just posted an updated plugin:
https://www.keyshot.com/resources/downloads/plugins
There is a known issue when transferring cameras. This will be fixed in KeyShot 7.2.
feher
feher
