Displacement breaks depending on Displacement Height
Started by monson67, November 30, 2018, 07:15:36 AM
monson67
I'm trying to model a beach scene using two planes. The first is the rocks at a slight angle with a displacement map applied. The second is the water. The idea is that the water would be seen flowing between the individual rocks thanks to the displacement map. To achieve the look I'm going for, I need the rocks' displacement to be significant enough. The problem is, too much height and the large artifacts in the displacement map begin to appear. This occurs whether I use 8-bit or 16-bit maps. Anyone have an idea why this is happening?
EDIT: GIFs don't appear to be animated. I've linked to animated versions.
KeyShot
This looks strange, and we have not seen other reports of this issue. Would you mind sharing your scene with us at support@luxion.com, so we can take a look at it?
Jikkk
I think the displacement map you used was a poor one. I have tried so many maps and I found out Poliigon's were the best.
Jikkk
Quote from: monson67 on December 03, 2018, 05:59:47 AM
That's what I used. https://www.poliigon.com/texture/stones-beach-001
It worked fine with me! And guess what - I used the poorest map (I just screenshot it).
Try to rescale your plane, I used 1m x 1m plane here.
