Advanced tranclucent material
Started by fa2020, January 05, 2017, 10:48:18 AM
fa2020
Hi guys,
Is it possible to get such a material in Keyshot?
LayC42
#2
The tricky part here is the semi-translucency. I.e. the thin parts have some transparency.
The Translucent materials in KeyShot 6 don't support that.
KeyShot 7 will have a new material type with advanced scattering that does support this.
Attached is an example.
Quote from: DriesV on January 06, 2017, 01:54:52 AM
KeyShot 7 will have a new material type with advanced scatting that does support this.
Render porn for my eyes Dries - Thanks for the insight :)
You're welcome, Martin.  ;)
It will be a flexible material with quite a wide range of applications. Basically anything that involves scattering in some way or another.
NM-92
You should check this out: https://www.keyshot.com/forum/index.php?topic=13949.0
This is an amazing material done by Eric. Not easy, but possible as you can see.
