I need some help.
Started by ufaforwork0, August 10, 2017, 07:34:38 AM
ufaforwork0
Hi there, My name's Thierry
When I attempt to use the higher predefined image pixel resolution settings for renders (anything above 4000 approx) I get a Black screen result in the render window. If I select a lower predefined setting, I will see my render result. If I then attempt to enter my own image resolution values, I get the same results. Black screen above 4k, visible image below 4k. สมัครufabet
Any helpful suggestions would be great. ทางเข้าufabet
Thank you
iMac, core i7, OSX 10.8.5, ZBrush Bridge. Keyshot 6.3.23
Is this your realtime setting?
