Colour problem about the stone way ( jewelery ring render )
Started by ramizramo, December 19, 2017, 10:46:33 PM
ramizramo
Hi. I am living a problem and want to share you.
If you look to in RedLine you will see some different colour. How can I solve and do normal colour this part.
Thank you so much for your helps.
Ramo
Maybe I'm colorblind (I know I am), but I do not see any color issue. Can you be more specific? Maybe outline the area exactly that is the problem? Also, a larger image might help.
ramizramo
Thank you for your interest. How can I remove the red?
I'm sorry. I am unable to see the red. I guess this would be a material property. Probably has to do with the metal you've applied and the color of the metal. Is there any red in your HDRI? If so, I would desaturate your environment.
Perhaps someone else will have some suggestions.
Esben Oxholm
I don't see anything red either. Only a darker shade of gold/orange which I think is due to the ring reflecting itself. I wouldn't look at this rendering and think that was a problem.
Cheers,
crazer
I know this is a stupid question but: do you try to change the environment?
Magnus Skogsfjord
I think this is the result of some reflections as others say. Maybe for these kind of detailed changes, you could tweak down the red channel in photoshop and see what happens? I see what you mean, but I don't see it as "red" either, more like heavy saturated metal color.
jitender.chaurasia
There is no red.... It is just a dark reflection. Try adding very less roughness (0.01) in material or try playing with environment.
Just looks to me like a very nice deep reflection of finely polished gold. Gold does have a hint of red to it in certain lighting. adding some roughness to inside the heavy reflections will help though, like the others said. Very nice work!
Josh3D
You might check the color calibration on your monitor as well.
ramizramo
thank you all for your interest
if i send my model i have a friend who can solve this problem to me?
