Scene Tree Drag and Drop Request
Started by jjeconomaki, March 29, 2012, 02:18:34 PM
jjeconomaki
I would like the ability to drag a model into a different branch of the tree structure.
This need arises out of the need to replace a single part in a complicated scene. One can import the new part fine, but it shows up at the bottom of the directory as an orphan. It needs to be with it's parent.
-John
PhilippeV8
While you're at it ... make it possible to drag them out as well ?
MarcB
Yes it is a good idea. I need too
When you import new object in the scene it is very complicate to place it at the good location
Placement of the object in the tree would have the effect to make him inherit the position of the branch.
