other audi R8 renders with lights
Started by Angelo, August 18, 2012, 05:46:22 AM
Angelo
tested with realtime settings and changing the enviroment lightning, the dualcore cant do much im afraid wish i had my 8 core working :/
feher
Love the wheels ! Do the headlamps have the bilbs ? If so I would light them up instead of the whole light. Or you could do a region render of the headlamps not lit and then overlay them on top so you can get some shape back into the headlamps.
Have you played with luxions HDR editor ? I would try to bring alittle more light into the dome so you can bring out some sheet metal shapes.
My door is always open if you need any help.
Thanks for sharing.
Tim
Angelo
thanks feher, the headlamps are just plane surfaces i havent come so far yet but what i had in mind is high details on this car so if you see the lights from a real R8 thats the results i want......i havent played with the editor yet but thanks for the tip, extremly helpful because i wanted the metal sheet to show more but didnt know how.
heres a closeup of the wheel its my first one detailed so there are some errors due to knowledge gaps from my side, you can see the tracks on the tire stick out instead of beeing unified with the whole tire but practice makes perfect.
thanks again :) // Angelo
jody
lettering on the tires needs to be flipped....rims are cool!!!
Angelo
flipped how? ive seen some referense pictures with text on them and they look the same as ive done direction wise
Angelo
and thanks the rims are fillet in every edge looking smooth :)
