A Couple Renders
Started by LocoDinero, December 26, 2013, 09:50:43 AM
LocoDinero
A couple of renders I was messing around with, good program fast render took 45 seconds on Camaro and 1 minute and 14 seconds on Bane, Amd Fx 6300 Processor Can I get and tips on how too get better renders ? and if they had Rigged animation import or internal animation system it will be the only program I will ever use.
Good start!  On the Camaro, I would suggest increasing the size relative to the backplate- it looks really small.  Size it to the foreground objects.  The wheels need more work as they look quite flat or "dull".  Ditto the black on the hood.  Give it a little shine and then pull it out with the environment.  Keep us updated!
