Portal, Series Two
Started by Speedster, August 06, 2014, 02:57:46 PM
Hi all;
Been playing with my DAZ-3D figure, working my way up to an image I've had in my head that looks at the issue of breast cancer, which my cousin Kathy recently lost her battle with.
A most interesting learning curve!  The figure is a stock DAZ shipped with the app.  I've created the pose I want, but can't figure out how to save the pose and then export it as an .fbx file. Maybe one of you would have some clues, as I can't find anything out from DAZ.  I exported the DAZ as .fbx into SolidWorks, where, interestingly, it opened as a Power Surface, a very powerful app I have for SW.  I did this as my direct .fbx import into KeyShot gave a lot of zigzag surfaces, but the SW conversion smoothed everything out.
KeyShot 5 Pro.  The new SolidWorks plug-in 3.0 is flawless now!  Lit entirely with IES lamps, two spots behind the portal, and a soft-box overhead for fill.  HDR set at zero.  Backplate is a label on a vertical plane so I could easily move it around for position and size, a really helpful trick for many rigs!  Rear wall flat black, and the floor and stairs are heavily frosted red glass on the visual surfaces, backed with chrome on the non-visual surfaces.  This is also a neat trick for many ground planes, and you can change the color to suit.
Despot
Hello Bill,
What you are trying to do is easily done, simply add your character, in my case, the Victoria preset figure. Pose the figure manually or apply a preset pose and then simply do a File >> Export >> and save as an .OBJ.
In the export options though, make sure you have 'Write Normals' flagged.
That's it really, the exported geometry should reflect the pose you chose - then just import into KS ensuring you have 'Import Normals' flagged
J
edwardo
All i would add to MM comment is that you can import the obj into something like maya, modo or even zbrush and sub-divide it if you need to. However I have only ever noticed tessellation from daz models when zoomed right into the eyes / ears / fingernails etc. And the new genesis 2 figure has 4x the polycount of the old one, so if your using that i doubt you need to subdivide the model in a third party app at all.
Good luck with whatever your endeavours are - cancer is a horrible thing that has taken my dad and my oldest childhood friend.
Remember folks... eat your broccoli !!!
Thanks, guys, for the guidance.  Actually, it was not a tessellation issue with the DAZ model, but just something weird about the surfaces- cleaned up fine in SolidWorks. I'm anxious now to play with exporting poses now that I have a handle on it.
Here's step two of the image...
