Floating License View Only Mode
Started by multitech, June 29, 2015, 05:52:25 AM
multitech
Hi Guys,
I would like to see KS 5/6 Pro Floating have a viewer only mode that does not require a license.  Similar to KS 5 non-floating unregistered mode.  That way the license can be in use but another CAD station can still export a BIP file using a KS plugin to check that the model geometry exported okay.  As of now, the floating version only gives you a server dialog box with no option to continue in view only mode.
Mike  8)
