Render For YAMAHA RX-V500D
Started by furqan aslam, January 13, 2016, 12:01:57 PM
furqan aslam
My best best Render
A little too dark for my liking on prod-vis but a massive thank you for sharing the bip :)
Esben Oxholm
Hi Furqan.
You have a great start here, but I'm certain that you can make them even better.
As TpwUK, I also think that the scene is a little to dark and the lighting a bit flat (I know lighting a square object is hard!).
Try and see if you can create a reflection comes across the front of the amp and enhances e.g. the little fillet between the top and bottom part.
Also, the background is a bit flat. Try adding a ground plane with some subtle texture and reflection and see if it makes the image more interesting.
For the radial brushed volume knob, you should use a bump map at a lower scale.
Thanks a lot for sharing the .bip! Are you able to save a package and share that as well? (File --> Save Package)
Then we'll also get all the textures used. If you do I can do a version where I adjust the things I mention above, if you are interested?
Best,
Esben
