Rendering products attached to the ceiling
Started by G2Art, February 16, 2017, 01:12:29 PM
G2Art
Hi, What if the ceiling is my "ground"?  When I import a model of a pendant lamp, I get the shadows on the gound.
I need flip the "ground" and make it behave like a ceiling - I need it to be above the product and not below it, and I need to have the shadows above the product as well, as you would see them on a ceiling in a room.
Any tips will be appreciated. Thanks!
HaroldL
I suppose you could add a Plane (Edit>Add Geometry) to your scene then move it to ceiling height, apply a material and "mount" your lights or product to it.
Quote from: G2Art on February 16, 2017, 01:12:29 PM
The solution to this is to build a box (room) have your model oriented in the correct position (attached to the ceiling) and import all that into KeyShot. As previously suggested, (if you don't have access to a 3D program) create a room using planes which can be added in KeyShot under the 'edit>add geometry' drop-down window. You can use the move tool in KeyShot to position everything as needed.
