Move single Object in Keyshot 2.2
Started by Jan Wnshmr, August 11, 2017, 02:31:29 AM
Jan Wnshmr
I'm using Keyshot since Version 4 came out and recently worked with Keyshot 6 which I loved.
But I changed my workplace and they use Keyshot 2.2. I ran into some issues reagarding the postitioning of objects in Keyshot 2.2.
The 3D Models come from Solid Works and mostly are assemblies or multi body parts. When I imported them in Keyshot 6 I could select single objects/bodies that belong to the same imported 3d file and move, rotate or scale them. Now in Keyshot 2.2 when I select a single object from an assembly to move it, every object is affected by the movement. Not just the ones that i selected. I really like to create explosions views and things like that in Keyshot so this is a real issue for me.
Am I making a mistake or is it not possible in this older version of Keyshot to only select and move/rotate/scale a single object?
Thanks in advance. :)
