Specifying CPU Core Usage
Started by Jesse.Art, July 19, 2018, 11:43:44 AM
Jesse.Art
In previous versions of KS I could specify the number of cores for KS to use when rendering. But I'm not finding that option nor documentation about it. Has it been removed or am I simply overlooking it?
And what was the previous version, and what is your current version?
Maybe you use KS7 and have the startup workspace active!? Then change this to standard and you'll find the missing dropdown.
In the render settings change the standard option to background and you'll get the cores to render option.
theAVator
See pics below. Is that what you're looking for?
I don't think it has changed much based on version or type of license.
However, the toolbar ribbon can be hidden. So if you're not seeing the ribbon, you can choose to show it under the Window dropdown menu.
Jesse.Art
Sorry, I should have ben more specific. I was referring to the CPU usage for viewport rendering. But MWo nailed it for me. Changing from the startup to standard did the trick.
Thanks a lot!
