Lighting presets transfer
Started by Eric Summers, September 25, 2020, 01:24:01 PM
Eric Summers
With KeyShot 10 on the horizon, it would be really nice if Lighting Presets could be brought over from 9 without having to manually do it one at a time.
Eric Summers
And having just updated to 10 this little frustration is coming back to the surface. It isn't too hard, but it would be nice to not have to re-enter multiple Lighting Presets. It seems like they should transfer over similar to how Workspaces do.
A build in feature would be nice. For a workaround you can open keyshot9settings.xml in a text editor and search for "lightingProfiles". Then you can copy the entire block from <lightingProfiles> to </lightingProfiles> and replace this block in keyshot10settings.xml. And then start KeyShot 10 and you'll get the custom lighting presets.
Eric Summers
Thanks Marco! That is a good way to do it, much quicker than re-entering everything. Cheers!
