Glass Problem
Started by Donavonjorge6638m, May 22, 2021, 07:58:38 PM
Donavonjorge6638m
Hi everyone. Does anyone know why when I put the material as Glass solid I get a line right in the middle. But When I do Glass online it goes away. Thank you in advance for all your help.
If the same effect appears when you activate refractive option in the glass material, then the effect could be affected by the environment and the refraction. If you use a ground plane with another material instead of the ground material type, the try to change this.
Or you can share this simple scene as KSP, so we can make better suggestions.
CheerEO
KristofDeHulsters
This might also be caused by switching to the GPU. I've had cases where the GPU gave some weird refractions but then resolved itself when I closed Keyshot and opened it back up.
