Twist animation Issues
Started by RaycerX, August 22, 2022, 09:28:53 AM
RaycerX
I'd like to start the twist animation at 25 degrees and then have it turn to zero degrees 3 seconds later. It seems the parameters only allow me to go one way (the opposite of what I want). When I mirror the animation, turn off the original, and then move it into place it just reverts back to the original one - so that's not a solution either. I'm using it in conjunction with the Zoom camera animation so simply reversing it in my NLE isn't an option either.
I really hope we will soon be able to keyframe camera movements, but I'm not holding my breath.
TGS808
In the Position and Orientation section, set your camera to Twist: 25º.
Add the Twist animation to the camera.
In the Animation Properties dialog box, set the degrees to -25.00º and have it last for three seconds
This will make the 25º twist on your camera animate back to the zero degree position.
