Rims details Bluelambo
Started by tsunami, November 08, 2012, 03:52:17 PM
tsunami
Here some new shots about rims details..
Thanks..
regards
Nice detail. But the tires are a bit too porous ;-)
PhilippeV8
#2
Yeah they look like black expanded polystyrene ...  It may look good from far, but for close-ups, you need to change that.
I would probably not get far on EPS tyres ... even with my Ford Fiesta MK6 !  ;D
That and the bumpmap on the brake disk ... reduce the scale on that !  ;)
CAClark
^^ What these guys said. I also think there is no real correlation between the environment and the lighting on the car. It's just white light where environment has a warmer cast to it.
Cheers!
tsunami
Quote from: CAClark on November 09, 2012, 12:16:23 AM
Cheers!
Hi Clark, i used the complete environment light,..is not an image backplate, so maybe i should get back on Ps postwork light..
Regards
kana
le hdri rajoute beaucoup de couleur  dans le detail de la jante ,jolie  ;)
tsunami
Quote from: kana on November 09, 2012, 09:56:00 AM
Hm yes it does!..as u can see there is not cold light ..because reflection on the rim are warm color...
regards
