wish list
Started by rainycat, December 11, 2012, 08:02:12 AM
rainycat
Apologies if these have been mentioned before (or already exist and I dont know them!)
Rotate model by set increment rather than freehand.
A Copy tool - instead of re-importing the model.
An easy way to switch off/on objects by layers.
More HDRi/matching backplates are always welcome.
More organic materials (packaging materials would be good)
rainycat
Bring in camera views from other bips.
Hopefully rollout the online rendering service to 'little users' like me.
PhilippeV8
QuoteRotate model by set increment rather than freehand.
This can be done.  On the "Project" panel; "Scene" tab, select a part.  On the "Position" tab that shows below on the same panel, you can translate, rotate or scale the object.
QuoteA Copy tool - instead of re-importing the model.
On the same panel, select an object, right click it and chose "Duplicate".  In v3.3, this only works for top level parts tho.
QuoteBring in camera views from other bips.
While importing another bip into your bip, on the Import Settings panel, chose "Advanced" at the bottom left.  You can enable "Import cameras" there.
rainycat
Thanks for the tips Phillippe , I will try those out. Much appreciated.
