Importing Pro-E files
Started by DBKeyshot, July 21, 2010, 04:43:12 AM
DBKeyshot
I've discovered the following issues with Importing Pro-E files (that don't occur when the plug-in is used directly from the program):
1) When importing, there's no option to choose which axis is up.
2) When browsing the files, it is very difficult to choose the latest version of a file, and when opening an assembly the assembly might not pick the latest parts. (This can be overcome by purging the directory first.)
Can you get me a small example for #2?
DBKeyshot
I sent you some Pro-E files to test with. Thanks very much!
