Emissive surface from Rhino to KS very confusing!
Started by rfollett, July 09, 2014, 05:00:29 AM
rfollett
Create a simple surface and apply emissive material, I want light to only omit on one side (ideally the front geometry although this seems reversed!)
But the visable to camera tick only works when 2 sided checked!
I want one side only and invisable to camera... Not possible?
rfollett
here is some proof.. You can see the surface from one side but not the other. I dont want to see it at ALL!
Rex
hey rfollett,
Thanks for sharing your bug find! I've documented it and filed it with development. Should be fixed in the next update. In the mean time you can use the Area light Diffuse which works correctly.
