Keyshot Plugin cannot be found
Started by Detox, June 07, 2015, 07:38:26 AM
Detox
Hi guys.
I installed the latest version of the Keyshot plugin and I still cannot find the plugin in the render tab?
Did anybody have problems like that before? My protk.dat file is in my Keyshot directory. Am I doing anything wrong?
Creo 3.0 is the students version.
Awesome if someone could help me.
Kind regards,
DetoX  :D
Chad Holton
Did you follow the readme after the plugin installation? If so, I wonder if the student version is restricting this somehow...
DonChunior
Quote from: Detox on June 07, 2015, 07:38:26 AM
... My protk.dat file is in my Keyshot directory. Am I doing anything wrong? ...
For sure it has nothing to do with the fact, you're using an educational version!
I assume, the the protk.dat file just does not get found by Creo ...
Either you add a config.pro option protkdat <PathToFile> which points to the protk.dat file, or you put the protk.dat file into the working directory of Creo.
Detox
It is in my working directory. And yes, I did follow the instructions after the installation. That's why I am a little bit confused.
