Pro E Plugin - Buggy.....Not Working Properly
Started by finn78, November 20, 2010, 01:42:14 PM
finn78
We have just upgraded from Keyshot Version 2.0 to 2.1 and now the Pro E plugin has lost functionality....so frustrating!
Keyshot installed fine & the plugin works, but here is the problem...
When you hit 'Render' in Pro E, you ussually get a dialog box allowing you to set the quality of the model (+/-0.5 etc).
This dialog loads up, but at the same time so does KeyShot i.e. loads the model before you get a chance to adjust the quality.
So what you end up with is a model quality always set to 0.5, (which is never enough) and dialog box then just sits there frozen!?
Can you please fix this ASAP. :-[
This is very strange. This is a Pro/E / plugin issue, not a KeyShot 2.1 issue. Can you try and reinstall the plugin. Did you make any changes to Pro/E itself?
