Author Topic: 1930 Ford Hot Rod  (Read 1053 times)
Offline TpwUK
1930 Ford Hot Rod
« on: September 21, 2015, 12:55:27 pm »
This model is huge and needs a lot of work doing to it to get it render ready, but you can get it from here https://grabcad.com/library/ford-hotrod-1
There was a couple of issues with the car paint and area lighting but you can work around these problems and there seems to be much better stability with build .204
Raw renders will put up the post edited images in the main forum
Offline edwardo
Re: 1930 Ford Hot Rod
« Reply #1 on: September 22, 2015, 06:24:48 am »
looking good (the headlamps look great!)
Feels like the back wheels need some love (There was an F1 or Indy car posted a while back that had fantastic texturing on the back tyres!)
Offline TpwUK
« Reply #2 on: September 22, 2015, 06:37:01 am »
Quote
Thanks Edwardo :)
Quote
I will see what I can do, there was problems with .204 build that prevented me from using Axalta Car Paints, it's fixed in the new .207 build so yes, I will try the paint again and if it works i will give the back tyres some much needed attention :)
