Rose Gold Diamond Ring
Started by ratanniraniya, October 27, 2015, 02:54:30 AM
ratanniraniya
Rose gold Diamond Ring. Any suggestion for improve the quality?
I think you could stand to get the ring/gold part to pop with some more contrast and hard highlights. It's very soft looking. Not sure if you used the default scene, but it kind of looks like it.
Suggestion is to do the diamond and ring separately. Create a viewset for the diamond and get it looking the best you can, then make a viewset for the ring. Make sure your camera is in the exact same position for both viewsets. If you're not familiar, viewsets allow you to change camera and environment settings almost like layers. So, render each one out along with a clown pass and use Photoshop or something similar to mask out the diamond and composite the two. I think you'll be pleased with the results.
ratanniraniya
Thank You Sir for guidence.
I will try the same and post new result very soon
