Script for rendering deformable meshes
Started by hstokholm, December 10, 2015, 04:47:19 AM
hstokholm
Attached is a script that supports rendering deformable meshes for Alembic and Maya files.
The workflow is as follows:
- Import first frame of the file. This is done through animation -> specific frame in the import dialog.
- Set up the scene with materials, environment, and camera.
- Run the script that continuously updates the geometry with the next frame and adds a image render to the queue.
If "Increase Keyshot frames" is checked the timeline in keyshot will also move each frame to allow for camera and material animations.
I tested it with the alembic octopus example file, and the result is attached.
- Heine
Esben Oxholm
Thanks for sharing Heine, and well described. Got it to work in one shot :)
Animation as alembic from modo 901:
Is it possible to activate motion blur on these?
TpwUK
Quote from: Esben Oxholm on December 10, 2015, 06:21:02 AM
I don't think you can Esben because you only have one frame in memory at any one time, although with ABC being a cache in theory you could manipulate things via scripting and somehow merge and fade previous render results to create a pseudo motion blur effect. Personally i think it would be easier to batch process the frames individually via PS or AE etc
hstokholm
Nice!
Unfortunately not. That can not be used for animations created through scripting.
Esben Oxholm
Quote from: TpwUK on December 10, 2015, 06:36:55 AM
Oh, yeah, true... Makes sense. Thanks for explaining.
Yup, the best then, I guess,  will be to apply some pseudo motion blur in AE.
evilmaul
thats sweet! thanks Heine!!
do you think this can be done differently in the future so that mblur can be applied to deformed objs as well?
As an alternative would make sense to output motion vectors as a map to then apply mbur in post?
Artur
Could anyone redirect me to a video tut for this one?
I am a novice in scripting for KS and I am trying to export a animation from C4D r 15 to KS6.
Thanks in advance.
hstokholm
Quote from: Artur on December 15, 2015, 12:42:30 AM
Hi Artur.
I am afraid that a video tutorial isn't available currently.
If you have KeyShot 6 pro you are able to render the animation frames using scripting.
C4D r 15 should be able to export the animation to an alembic file (.abc) which can be used with this script.
To actually run the script you open the scripting console which are located in "Window -> Scripting Console" in the menu bar.
In the "Scripts" tab you have the option to import the script, and then it can be used by double clicking it.
If you have any specific questions feel free to ask.
Quote from: evilmaul on December 10, 2015, 11:26:23 AM
Good to hear it's useful. And yes it would make sense to support motion blur in the future. Maybe for now motion vectors can be output from maya and then combined in post?
Artur
Sorry for the recurrent request but maybe a step by step guide:
1- ...
2-...
3-...
hstokholm
No problem Artur.
1. Export from cinema 4d to an Alembic file.
2. Import first frame of the file. This is done through animation -> specific frame in the import dialog.
3. Set up the scene as you want it with materials, environment, and camera.
4. Open the scripting console which are located in "Window -> Scripting Console" in the menu bar and choose the "scripts" tab.
5. Import the script "Add deformable mesh frames to queue.py", and then it can be used by double clicking it.
6. Fill out the options in the "Add deformable mesh frames to queue" dialog and press ok.
7. The geometry are now being updated for all frames, and a render is added to the queue for each frame.
Feel free to ask if anything is unclear.
reidsl
From the sound of it this is just me but Im having issues.  I ran the script fine, its the output that killing me.  First even though it shows that it saved to the correct folder in the output window, the files end up in my Keyshot Resources folder.  Second and most important, for some reason all of my files are .ext files (DeformerTEST.mb.00000.tif.ext) which make them worthless.  What am I doing wrong here?
redcode
Quote from: reidsl on January 08, 2016, 09:40:38 AM
I'm having the same exact problem! The script runs fine (very fast) and then I get the files ending up in the KeyShot Resources folder and all the output files have the extension .ext and I can't open them. What is going on? Please let us know. I was very disappointed when I discovered KeyShot couldn't import deformation files from Maya or through FBX. This seemed like a passable workaround. Please help us.
hstokholm
The .ext files are for keyshots render queue. The scripts add all the renders to the render queue, and you then have to manually process the queue. (Render -> Queue -> Process Queue)
dennisvolkerts
#13
Quote from: hstokholm on December 10, 2015, 04:47:19 AM
- Heine
Thnx for the script but it keeps crashing... is there some option in the script to keep it going? after 8 frames it seams to crash... i7 - 24 RAM, Nvidia Quadro K2100M (4GB)
my mesh count isnt that high...
5 mil poligons..
One character is animating.
abc file is 1.46GB
Can you add a option for maximum ram?
Or do you know some online scripts that can handle it?
obj sequence I heart about, this is the first I tried and I preffer alembic
thnx
what version of KeyShot are you using? Make sure that you are on the latest version 6.2.85. It was just released.
