Personal Build : i7 5820K oc @4.3 Ghz 120 FPS
Started by ace cool, January 06, 2016, 10:34:02 AM
ace cool
i7 5820K
OC @ 4.3 Ghz - 120 FPS
OC @ 3.8 GHz - 107 FPS
Stock @ 3.3 GHz - 96 FPS
windows 8.1
Liquid cooled
16 GB DDR4
Nvidia GeForce GTX 960 4 GB
;D
Arian Shamil
ace cool
#2
stock clock 3.3 but today i overclocked it to 3.8 and don't know why i went down to 107 fps :( figuring it out will update :)
Update:-
now in stock  @3.3 Ghz i am getting up to 96 Fps
i think in very first time my resolution got disturbed (i remember i had set it manually but this is the only thing which can happen)
ace cool
OK latest update i managed to get my CPU stable at 4.3 GHz with 1.25V and 60 C temp and woohoo 120 FPS now i am satisfied.
pizzalover2
Quote from: ace cool on January 07, 2016, 02:09:02 PM
How do you overclock the CPU to 4.3 GHz if the Max Turbo Frequency is 3.6 GHz?
https://ark.intel.com/products/82932/Intel-Core-i7-5820K-Processor-15M-Cache-up-to-3_60-GHz
Probably I don't understand how overclocking works :)
marcusha
#5
Quote from: pizzalover2 on January 11, 2017, 05:13:15 AM
Overclocking is done in the computers BIOS, witch you can acess while booting. It is a matter of tweaking the number of Ghz the CPU will run at. Usually the manufacturer set it lower to provide stabillity and to produce less heat.
You can however run CPU's stable on a higher clockspeed than factory, by increasing the amount of voltage delivered to the CPU, there by allowing it to run stable. This will also produce more heat, and there by requireing a better cooling solution.
I have a i7 5820k running at 4,5 Ghz stable, but the highest achiveable overclock will vary from chip to chip.
I wouldnt recommend overclocking if you do not know what you are doing, as it can lead to a ruined processor.
i7 5820k @4,5Ghz - 127 Fps
