Light noise at night
Started by ThomasVINCENT, March 15, 2016, 04:45:45 AM
ThomasVINCENT
Since i use KeyShot i didn't get to fix the noise on the render when i use light materials.
This time i ask you if you can help me.
I don't know if the noise come from the light or the material "touched" by the light.
There is a little bit noise on the yellow part of the boat and a lot on the metal structure.
Thank for your help.
Artur
Same problem here.
I think the bump surfaces have something to do with this.
But no clue on the solution.
NM-92
Had this same issue. Using emissive and area lights and a rough material for the ground plane.
ThomasVINCENT
Did you try to add a ground in keyshot ?
In my memories it can change the light on the ground.
