How are those cheesy iPhone press shots illuminated?
Started by Flix, December 25, 2010, 09:06:31 PM
Flix
More here: http://www.engadget.com/photos/iphone-4-press-shots/
No matter what I do or how I try to position a flat object, its surface will always be illuminated uniformly. How do they obtain those distinct light cutoffs?
rkulshrestha
Check out the product visualization webinar - easy!
Shivani
Flix
Thank you! I watched the tutorial and it was exactly what I needed.
justindustrial
Quote from: Flix on December 25, 2010, 09:06:31 PM
Photoshop.
The technique is quite simple acutally, just mask out the surface that you want a reflection on (the flat surface), create a new layer with a slight gradient from grey to white, and change the blending to overlay or screen or muliply, whichever looks best, then do a selection and delete half of the reflection. Bingo!
Flix
Thank you! While the idea of using Photoshop for this seems a little crude, it's definitely faster than creating, importing and positioning the geometry for obtaining the light sources mentioned in the aforementioned webinar!
j4m35
I have just used reflection plane (triangle) in order to achieve the effect on the iphone but the reflection is rather solid (no gradient). Then I decided to use photoshop to obtain the image as shown by you.
