Interior mode render bugs?
Started by bronson, April 07, 2016, 06:08:01 PM
bronson
I am testing the interior mode of KS6.
I made a 6 x 6 x 3,5m room with one window, then assigned paint or plastic materials on the walls.
The only light source is HDRI.
But there is a weird dark textures on all over my walls. It looks like an over-size texture map.
I am just using standard  plastic or paint materials. I have adjusted the roughness also.
No texture apply at all.
Is it render settings issue? Or KS6 bugs?
Here is the screenshot.
Pls help.
Bronson
That's just because you have not let it render long enough ... Use max samples or max time
bronson
Quote from: TpwUK on April 08, 2016, 06:21:31 AM
Martin,
Thanks for the reply. I will try as your suggestion.
Bronson
