Author Topic: Needing Help Making These 3 Finishes  (Read 10607 times)
Offline TpwUK
Re: Needing Help Making These 3 Finishes
« Reply #15 on: June 14, 2016, 10:05:47 am »
Thanks that helps me better :)
Crank metal Roughness to full 1
Samples 16
The you can use those bitmap swatches to do things like this .... And get results like the last image. This way you still have bump and roughness to play with to further enhance your material to your needs. If you don't like the scratches procedural, there is fractal noise and cellular noise to play with too :)
Just play, you won't hurt anything
« Last Edit: June 14, 2016, 10:11:42 am by TpwUK »
Offline TileWareProducts
« Reply #16 on: August 10, 2016, 09:41:47 am »
Trying to match the Brushed Nickel finish of the photograph that I had posted.
Advice/Comments/Suggestions?
